C6501 yellow lines and scratches on drums...
  • inkhouse
    • 14
    [Misc] C6501 yellow lines and scratches on drums...
    Hello , i got a c6501 and i have 2 problems:
    1) i got yellow lines in the background on the left side of paper only and few vertical lines all over the paper no matter what i print
    2)drum got scratch on left side after 200 print paper and its become worse the more paper i print
    i have read most of the post here and i have try many solutions (corona replacement, drum preposition,dv swap place,i clean all the lens sensor etc.) still i got same problem even when i change new drum i got lines at 1st print in the same spots ...
    any can help me !!tnxxx
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: C6501 yellow lines and scratches on drums...
    sorry, that attachment is horrible.
    please attach a full size sample.
    • Toxic
      • 698
      Drum have contact with developing unit and transfer belt so did you check and replace something in TBU (belt,1st tr. rollers...) ?
      Is the damage visible and always on Y drum?
      • inkhouse
        • 14
        Hello , thanks for the fast answer here is new pics..
        C6501 - Album on Imgur
        let me know if u can see pics
        • Synthohol
          • 5849
          looks like corona damage to me.
          • inkhouse
            • 14
            Well... i thought that too but i replace them and still got the same result
            • Synthohol
              • 5849
              6501 the corona height is adjustable IIRC, did anyone mess with the screw?
              is it OEM toner and developer? maybe a bad bottle of toner that made little stones that scratch it?
              how does the mag roller look?
              • Toxic
                • 698
                If i see good you are using replacement drums,not complete OEM drum unit?
                Have you replace only drum or drum and drum cleaning blade because it looks like cleaning blade damaging drum?
                Can you wipe this yellow lines or its physical damage on drum surface?
                I use only OEM DU-104 on this 5501/6501 and never have problems,they last for 200-300% over life without quality issue.
                • sadanand
                  • 62
                  Blade flipping problem check Drum cleaning blade
                  • inkhouse
                    • 14
                    this screw is on the slot of corona on in drum unit?
                    this problem start before i replace anything on the machine
                    • inkhouse
                      • 14
                      i replace drum with blade always i tried both oem and long life drums same result lines start at 1st print ,scratches after 200 pages.
                      i cant wipe them i tried its permanent.
                      • inkhouse
                        • 14
                        i have replace the the yellow blade 3 times same result the thing is like i said i can see this lines on print even before the drum show scratches...
                        • sadanand
                          • 62
                          Change developer and toner ,because that is the only thing touching drum ,also check telloe transfer rolller in ibt section
                          • methogod
                            • Dec 2008
                            • 921
                            DU102 drums only.
                            do not use DU104.
                            make sure your removing the red screws from the drums when replacing.
                            what is meter/life of DV unit? DV?
                            • inkhouse
                              • 14
                              Originally posted by methogod
                              DU102 drums only.
                              do not use DU104.
                              what red screws?
