Bizhub c280 transfer belt advice please
Re: Bizhub c280 transfer belt advice please
Not sure how long but it's a good while. But it can be set to not stop if not set that way already.
There are 2 options, replace just the fuse to reset (or "new release" in service mode, not sure if this model had it yet) or rebuild with aftermarket kit (belt, cl bld & fuse if used)
I've had good results with both options and saved a lot of money while customer saved a lot. If contract customer I would just reset, if charge customer sell them rebuilt.
Actually 3 options if you want to include a new OEM belt. -
Contract customer; provided the prints are OK, reset by doing "New Release".
For others we get after market belt. If you get the complete belt unit, not only the belt + cleaning blade, you better remove all paper separator fingers. Had once a brandnew after market belt that crashed cause the finger in the middle plowed through the belt.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
By the way I never use aftermarket toner or developer in ANY color copier or printer no matter how much $$ it will save. I do use aftermarket toner in B&W copiers & printers.Comment
Yes I'd like to save them a bit of money and make a profit, there's nothing in it for me if I buy the OEM unit really. In that case I would do a reset and wait till it fails.
However, if you have any suggestions for where to get a rebuild kit or the parts, please comment below, thanks.Comment
Hello again. Good news is the copier is still working.
I've been on site today for another issue and with closer inspection it seems that the unit actually reporting that the transfer roller needs replacing soon.
Looking at the life limit section below, I can see that most of the black consumables have already been reset.
I'm going to look for a new developer, because I have a faint print out that I'm sure is down to the developer unit. Everything else I will leave alone until more issues arise I think. Is the reset procedure for the roller the same as for the transfer belt? Will the roller cause a print stop?
Consumables Yellow 42% Magenta 72% Cyan 54% Black 44% Cyan 89% 11/1/2012 12/5/2020 Magenta 89% 11/1/2012 12/5/2020 Yellow 89% 11/1/2012 12/5/2020 Black 100% 19/7/2017 6/11/2018 Cyan 55% 11/1/2012 6/7/2025 Magenta 55% 11/1/2012 6/7/2025 Yellow 55% 11/1/2012 6/7/2025 Black 100% 11/1/2012 1/11/2017 Ozone Filter 100% 10/6/2015 18/2/2019 Fusing Unit 93% 21/3/2014 3/11/2019 Image Transfer Belt Unit 100% 21/3/2014 8/5/2017 Transfer Roller Unit 100% 10/6/2015 18/2/2019 Waste Toner Box Ready Comment
Looking at those life counts not sure why you need to replace or reset anything? Also unless you or someone already reset the consumables you shouldn't be getting a faint print with those counts.
Makes it harder to troubleshoot when life counters have been reset, unless you keep good track of what you reset and write in machine log (the log I always forget to fill out for the last 40 yrs!)
You can reset the transfer roller message in service mode, life, "clear" count.Comment
Thanks for the reply, I'm pretty sure the ones at 100% have already been reset. I have not reset anything before on this printer and some of the end of life forcasts are years old, so I'm guessing that they were reset at some point close to the end of life forcast date.Comment
