C454 - Paper comes out curly (approximately from the half)
  • Laserbeam
    • Aug 2011
    • 152
    #16
    Re: C454 - Paper comes out curly (approximately from the half)
    okay, this attempt I will do tomorrow!
    • fishleg
      • Mar 2009
      • 426
      #17
      Check paper loop sensor above transfer roller, that be my guess .
      • Laserbeam
        • Aug 2011
        • 152
        #18
        Now I've changed following components:
        vertical Transport assy (which includes the paper loop sensor above the transfer roller)
        both registration rollers and bearings
        registration actuator
        CL6 from the main drive assy (which drives the registration rollers)
        The problem still exists!!! the paper Comes out curly!!!
        • tsbservice
          Field tech
          • 8053
          #19
          Does the distance from leading edge to the first curl is the same on different paper formats?
          Can't remember but did it curl from bypass tray?
          I would try to cheat side door and figure a way to run copy without jamming up to the fuser to see paper drive.
          • allan
            RTFM!!
            • 5462
            #20
            Could be faulty control from a shot motor driver. Try control board.
            Whatever
            • Gaffers01
              • May 2011
              • 335
              #21
              Just a sudden thought, have you tried pulling the paper out when it starts to exit machine and see if it still curled. I remember on a c253 with million odd copies a few years ago at an engineering company they had a similar problem but only 2 ripples on the page and ended up being the exit tray. I ended up swapping with a different one.
              • Laserbeam
                • Aug 2011
                • 152
                #22
                @ Gaffers01
                yes, I had already made this attempt. As soon as the paper become visible, I pulled it out under strong tension.
                But the paper is still curled. Thus, the possibility that the paper exit unit is the cause, is eliminated.
                @tsbservice
                yes, the distance from leading edge to the first curl is about the same on different paper formats. It is also curled from the bypass-tray.
                • Laserbeam
                  • Aug 2011
                  • 152
                  #23
                  Problem solved!!!
                  The cause was in the reversal unit. Unfortunately, an error encured during my first error Analysis. I had a reversal unit installed from a BH C224.
                  However, this unit has a different gear (PN A161819200, 18T). The unit from BH C454 has a gear (A4FJ819200) with only 17 teeth.
                  Thus, the drive roller runs too fast and causes the curles in the paper.
                    • 23010
                    #24
                    Congratulations on finding that. Only a tech could cause that. Such problems can be very hard to track down. =^..^=
                    • Barry97
                      • Jun 2022
                      • 23
                      #25
                      Originally posted by Laserbeam
                      Problem solved!!!
                      I tried everthing here. I am still getting that wavey print out on paper. It does not Jam just does the wavy printout. I even changed the fusing motor. The outcome is the same with the other trays on the machine.
                      • techsxge
                        • Jan 2022
                        • 660
                        #26
                        Same procedure for you: Stop the Machiine mid-Job and check where the paper turns curly.
                        • Kenny
                          • Jun 2009
                          • 533
                          #27
                          have you made sure ALL the gears are correct on the reversal unit
                          C454
                          (23) - A161819600Gear 18/26T
                          (18) - A161819701Gear 22/27T
                          Screenshot 2022-08-12 at 10-21-41 A4FJ - C454-PM.pdf.jpgScreenshot 2022-08-12 at 10-21-29 A4FJ - C454-PM.pdf.jpg
                          C454E
                          (16) - A0ED811800Gear 22/23T
                          (22) - A0ED813200Gear 22/26T
                          Screenshot 2022-08-12 at 10-21-03 A5C0 - C454e-PM.pdf.jpgScreenshot 2022-08-12 at 10-20-37 A5C0 - C454e-PM.pdf.jpg
                          • Barry97
                            • Jun 2022
                            • 23
                            #28
                            C454
                            [ATTACH=CONFIG]54326[/ATTACH][ATTACH=CONFIG]54327[/ATTACH]
                            C454E
                            [ATTACH=CONFIG]54328[/ATTACH][ATTACH=CONFIG]54329[/ATTACH]
                            I replaced the whole unit. print out still curls. There is no paper jam. While it is printing I did open to see where it starts, it happens after it passes the fusing unit.
                            this is what i get.
                            I checked the gears and they all are fine. No wear on them.
                            • Barry97
                              • Jun 2022
                              • 23
                              #29
                              [ATTACH=CONFIG]54333[/ATTACH][ATTACH=CONFIG]54334[/ATTACH]
                              this is what i get.
                              I even tried the firmware update. Still wavy!!!!
                              • tech51
                                • 846
                                #30
                                Does it happen on all paper sizes? What size is that in your photo?
