Bizhub C224e SSD Replacement
  • Ari007
    • Apr 2019
    • 49
    [Misc] Bizhub C224e SSD Replacement
    Hello Techs..
    [DISCLAIMER] "I'm an end user turned tech with sensible knowledge."
    Earlier I've posted this issue: http://www.copytechnet.com/forums/ko...57=#post747660
    And finally the new SSD board arrived. I have the service manual & aware of the instructions but I need some advise from you guys, the experienced techs who did ssd replacement.
    Can anyone guide me through the steps?
    Machine: Bizhub C224e
    Last Boot Firmware: G20-M1
    SSD Firmware Ver.: 6.05m
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C224e SSD Replacement
    Remove rear cover
    Replace SSD
    Replace rear cover
    Load firmware
    Remember to switch it off first.
    There is nothing to backup because that is where the backup goes.
    If the machine was still working may be backup authentication info and address book.
    Just verify SSD Ver after first startup.
    Whatever
    • Ari007
      • Apr 2019
      • 49
      Originally posted by allan
      Remove rear cover
      Replace SSD
      Replace rear cover
      Load firmware
      I did these things but the following things are happening.
      Power on> shows 2 bars> restarts> shows 4bars> then screen goes black..
      • allan
        RTFM!!
        • 5462
        Remove rear cover
        Replace SSD
        Replace rear cover
        Load firmware
        * Note contact KM tech support on replacement...
        Whatever
        • tsbservice
          Field tech
          • 8008
          Try to disconnect HDD harness and power on the machine.
          • Ari007
            • Apr 2019
            • 49
            Sorry for late update, the machine is working fine now. It was a problem with the firmware. Earlier I was flashing with m0 & m1 firmware but that thing did not worked when I flashed the k9 firmware the machine booted up. I have turned off the hdd from service mode. I have to re-do the calibration.
            Thanks everyone for helping.
            • Ari007
              • Apr 2019
              • 49
              Also I'm using "Data Administrator" to manage all settings and found it very useful.
              Some of you may have used it earlier and some people haven't... please go here: Data Administrator - Utilities - Solution Software | KONICA MINOLTA
              • r6po
                • Apr 2020
                • 15
                I have a similar problem.
                Can you tell me how you did the firmware update? and where to find it?
                My bizhub c224e photocopier cannot start up, it reboots and it is impossible to access the touch screen!
                In addition, for the past few weeks, it has been impossible to access the copier via the web interface.
                Thanks for your help..
                • Ari007
                  • Apr 2019
                  • 49
                  Your machine gets stuck at 2 bars?
                  Please explain the problem a bit.
                  • tsbservice
                    Field tech
                    • 8008
                    Do you have new SSD? Cuz you're gonna need it. Better start your own thread.
                    • r6po
                      • Apr 2020
                      • 15
                      Hello, thank you for your answer.
                      When I turn on the main switch, the screen turns on, there are 2 bars, a beep, the start button lights up and then it restarts!
                      On the advice Ari007 of I will open a new thread.
                      • r6po
                        • Apr 2020
                        • 15
                        You think it's the SSD?
                        No, I don't have one yet.
                        Ok I open a new thread.
                        Thank you .
                        • Albonline
                          • Sep 2008
                          • 1150
                          Thank you .
                          if you have a dual scan board try uninstalling it. seen it cause this.
                          • r6po
                            • Apr 2020
                            • 15
                            thanks for the advice
