Paper jam
  • mayorg
    • Feb 2015
    • 53
    [Jamming] Paper jam
    I have a problem with my konica minolta c258 showing misfeed detected. Remove paper as indicated by circle code 14. Have cheack every were I can find any paper in side machine please help me out
    Sent from my SM-N950U using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Paper jam
    Try to open and close every door.
    What is the actual jam code?xx-xx?
    • mayorg
      • Feb 2015
      • 53
      Re: Paper jam
      14
      • mayorg
        • Feb 2015
        • 53
        Re: Paper jam
        I mean code 14
        • mayorg
          • Feb 2015
          • 53
          Re: Paper jam
          It show code 14
          • emujo2
            • Mar 2017
            • 1579
            Re: Paper jam
            Try looking in the duplex section..If you truly do not see any paper here, then you may have a torn piece of paper blocking an actuator, or a non working sensor. There are 2 sections of the side door, one hides the turnover (duplex) area.
            • mayorg
              • Feb 2015
              • 53
              Re: Paper jam
              How can I get the duplex sensor
              • emujo2
                • Mar 2017
                • 1579
                Re: Paper jam
                This forum isn't designed to help an end user dig into a MFP to find broken sensors. If you do not see a piece of paper in this section and you are still showing a jam 14 then call a tech.
                • mayorg
                  • Feb 2015
                  • 53
                  Re: Paper jam
                  Am also a technician this is my first time I across this code
                  • emujo2
                    • Mar 2017
                    • 1579
                    Re: Paper jam
                    Then you must be the least trained tech I've ever heard of..This isn't even a trouble code..It's a jam code meant to direct the operator where to look for a jam. If you, as a tech, cannot determine if it's a torn piece of paper, a bad sensor, or paper still remaining in the paper path then you probably should be taking phone calls and sending tickets out to trained techs..
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      Re: Paper jam
                      Exactly what I was going to say!
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • Synthohol
                        • 5922
                        Re: Paper jam
                        14 is not a jam code. It's a location.
                        Jam codes are "j##-##"
                        Look in the jam history if it's not displayed
