Konica Minolta C454e 30-03 jams
  • Kenny
    • Jun 2009
    • 524
    [Jamming] Konica Minolta C454e 30-03 jams
    Hi guys,
    We currently have a Konica C454e at a customers which is getting 30-03 jam codes (jamming in the fusing unit) when printing high quality prints on A4 80gsm, it works absolutely fine when printing normal text documents. At first we believed the issue was down to the paper since it was jamming and had fusing issues, we got them to change the paper and worked!!(tried multiple fusing units as they keep getting damaged from customer removing jams). Came back to the customers today and has done the exact same thing with the paper getting jammed in the fusing unit.
    Note: Firmware is all up to date.
    Currently using - Premier Elements Earth White A4 80gsm Paper
    any help would be appreciated!!!
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Konica Minolta C454e 30-03 jams
    CL8 needs replaced which is the exit drive clutch.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • tsbservice
      Field tech
      • 7999
      Agree with srvctec.
      Use search option, there is how-to pdf file where blackcat4866 explained disassemble.
      • tech51
        • 846
        Is the paper getting through the fuser or concertina jamming in the rollers?
        • Kenny
          • Jun 2009
          • 524
          • tech51
            • 846
            Do these high quality documents have a high colour content?
            If if so I would look at increasing the lead edge blank.
            I have had issues with the C454e and heavy colour coverage causing fuser jams and maxing out the lead edge blank helps with this.
            Just as an aside though there is a mylar guide just below the tbelt which can get deformed when the belt is replaced. This can catch the paper and prevent it from entering the fuser.
            • Kenny
              • Jun 2009
              • 524
              What do you recommend to change the Lead edge to? I have never really adjusted this option.
              • Kenny
                • Jun 2009
                • 524
                  • 23002
                  What type of media are you using?
                  • fredr
                    • May 2019
                    • 11
                    Just reset the printer switch off the printer then hold reset button then switch on the printer to troubleshoot...the machine should be ok
                    • jerry_lam1210
                      • 5
                      You're so smart !
