driver favourites + output method
  • rrrohan
    • Sep 2011
    • 1977
    Trying to setup a favourite in driver for secure print.
    Am I missing something or can't the driver save the output method?
  • Synthohol
    Certified Konica Expert
    • 5832
    Re: driver favourites + output method
    upper right hand corner is the profile/preset box.
    save it as a preset.
    beg your pardon, its now called favorites near the top of the "My Tab" tab, set up the job and add one.
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      I just tried saving a favorite on C360 series driver and an 8 series. There is no way to save the output method as part of the info in the favorites. In both cases, the output method did not change to Secure Print, even though I saved a favorite with Secure Print selected. It just goes back to print as the output method. The only way I know of to set Secure Print as your output method is to go into devices and printers, select printing preferences of the desired printer and set secure print to the output method.
      It appears that no matter what is chosen as the output method, that setting stays as the output method until changed. I opened and closed the driver window and each time, whatever was last chosen as the output method is what was still there. Choosing a different favorite made no difference in the output method.
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • Synthohol
        • 5832
        create another queue and under advanced, printing defaults select secure print and apply.
        now when they want to secure print just use that queue from the dropdown in the app.
        • allan
          RTFM!!
          • 5462
          Agreed. Just setup another "printer" called by that description and setup the default.
          Whatever
            • 14754
            Have you ever tried Pagescope Direct Print? It is an app that allows you to simply drag and drop a print job. You can have multiple setups on your desktop.
            You can download it from the Pagescope utilities website.
