Konica Minolta C258 Trouble Code C-D3A0
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C258 Trouble Code C-D3A0
    Getting this code
    Please advise
  • tsbservice
    Field tech
    • 8064
    Re: Konica Minolta C258 Trouble Code C-D3A0
    What did you do on the machine prior the code?
    Did you swap boards? We need more information to help you.
    This is not a tech question, more like enduser
    • Synthohol
      Certified Konica Expert
      • 5906
      Do you want the service manual?
      Gimme a min and ck your pms
      • minoltaed
        • Aug 2009
        • 45
        • mearmi
          • Oct 2010
          • 350
          Thanks for your reply. Have replaced the MFP board but no luck.
          Please advise what it could be?
          Regards
          • arahael
            • Mar 2013
            • 97
            Replace emmc
            • mearmi
              • Oct 2010
              • 350
              Originally posted by arahael
              Replace emmc
              can we grab Emmc from another machine and use it?
              • tsbservice
                Field tech
                • 8064
                Regards
                1. Check if this error occurs because the original MFP board (MFPB) was replaced with one removed from another machine. If so, reinstall the original board, operate the MFP, and verify if the error returns.
                2. Perform Clear All Data.
                a. Call the Service Mode to the screen.
                b. Touch [System 1] -> [Initialization] -> [Clear All Data][System 2] -> [HDD] -> [Installed].
                g. Exit the Service Mode and then turn off the main power switch and turn it on again after waiting 10 seconds.
                • nicaciobhz
                  • Oct 2018
                  • 5
                  It works well for me!
                  Tks man
