C285 chipping
  • jonpaul
    • Jul 2014
    • 59
    C285 chipping
    We have tried to colour chip a black drum for a c258 and no colour is trans ferred are we missing something.we did remove the block on the drum so it fitted.Thanks
  • Bix
    • Apr 2018
    • 1421
    Re: C285 chipping
    Counters? State of consumables? Do you use OEM consumables? Do you have a picture of the problem?
    • jonpaul
      • Jul 2014
      • 59
      Re: C285 chipping
      They are OEM black drums with colour chip, the counter zeroed but not change the installation date,the colour does not register on test.The drum we replaced was a black drum with colour chip and that worked.We tried another drum in case the first was faulty,but that did the same.
      • tsbservice
        Field tech
        • 8020
        Re: C285 chipping
        Here:
        Bizhub C258 color and Bw drum unit
        • wolfy
          • Jun 2019
          • 3
          Re: C285 chipping
          you will have to change the end block on the drum unit at the front as it keeps the drum and dev unit apart , takes 5 mins
          • jonpaul
            • Jul 2014
            • 59
            Re: C285 chipping
            is that the lump of plastic on the right hand side that stops the drum going in a colour slot?
