bizhub PRESS 1052 print rotation problem
  • joaodaffonsojr
    • Aug 2014
    • 53
    Re: bizhub PRESS 1052 print rotation problem
    end user or tech?
    have you tried CUSTOM settings?
    what the hell have you tried very limited info ..
    suspect end user.
    • joaodaffonsojr
      • Aug 2014
      • 53
      end user or tech?
      suspect end user.
      END User my friend ...
      The paper is configured CUSTOM 320x240mm.
      running win10 x64
      Adobe Acrobat DC
      ps driver version 5.0.554
      I tried everything on the driver all kinds of configuration !
      what info do you need more ?
      thanks
        running win10 x64
        Adobe Acrobat DC
        thanks
        ok bud..
        sometimes the PS driver isn't always right ... PCL5e or 6...
        what is the config on the on the driber? the same? and on paper trays?
        • joaodaffonsojr
          • Aug 2014
          • 53
          ok bud..
          • tsbservice
            Field tech
            • 8020
            Try it Landscape instead of Portrait. Or change width with height and vice versa. It's not that hard like rocket science, it's simple printer driver, with some trials and errors you will make it. Check printer specs and make sure this size is within them.
            • joaodaffonsojr
              • Aug 2014
              • 53
              I tried it all. No success.
              Seems to be a bug in the PS Driver with custom format.
                • 23009
                Specs say 324mm width x 463mm length ... so technically possible. What tray are you selecting? Can you program the tray as 320x240 instead of 240x320? =^..^=
                • joaodaffonsojr
                  • Aug 2014
                  • 53
                  Hi !
                  Did that already !
                  Nothig worked right.
                    • 23009
                    Have we determined yet if the paper is accepted as 320x240 in the tray and will copy? If yes, then its a driver issue. =^..^=
