we had a few jams then got this internatl Error message
  • positiveg
    • Jun 2018
    • 299
    [Error Code] we had a few jams then got this internatl Error message
    Please see the image
    Not sure why it happened.
    We were running some booklets.
  • tsbservice
    Field tech
    • 8064
    Re: we had a few jams then got this internatl Error message
    Model? Did you reboot the machine?
    • positiveg
      • Jun 2018
      • 299
      the Bizhub C454E
      yeah restarted it
      happened like twice not really sure why
      It's running now though
      • allan
        RTFM!!
        • 5462
        If you can get into service mode.
        Go to the service code history check for the latest error codes.
        Also check the jam codes.
        Whatever
          • 23010
          Do you want a guess? I suspect you've got a developer density issue. When you look at the error log you'll know which color to check. It's common to have the hopper bushings bind up. You'll hear that toner motor chattering. If you take the engine cover off you can watch which drive is chattering. Most of the time, just vacuuming out the hopper and cleaning the bushings on the hopper, will let the drive turn. the hopper will fill with toner and the developer will tone up immediately. =^..^=
          • positiveg
            • Jun 2018
            • 299
            Thanks all for this
            Summen strange though all the drums saying 0%
            I never seen this where all drums say 0% at the same time.
            • tsbservice
              Field tech
              • 8064
              Did you check what allan suggested?
              • positiveg
                • Jun 2018
                • 299
                No haven't done so as yet.
                After i posted the message it came back up, we just thought it was due to multiple jams
                • tsbservice
                  Field tech
                  • 8064
                  Better read your Manual.
                  Internal Error. Auto Cancel.
                  To set whether or not to automatically reset trouble when a trouble code classified as rank B or C occurs.
                  Default setting
                  Rank B: Yes
                  Rank C: Yes
                  Behavior
                  When this setting is set to "Yes," MFP operates as follows:
                  When specified trouble occurs, the trouble warning screen displays for about 10 seconds the message that the trouble is automatically reset. Then automatic trouble reset is performed.
                  If the trouble reset is successful, MFP can be used.
                  If the trouble reset fails, retry is performed. (The number of retries is up to 2 times.)
