С 287 , codes C FA17, C 40C5
  • pinspin
    • Oct 2011
    • 156
    [Error Code] С 287 , codes C FA17, C 40C5
    Hello. Copier C287 showed the codes С9402, С6751, СFА17, С40С5. We replaced CCD and performed Firmware Update , but we get codes СFА17, С40С5 (for example ,when resizing a copy). This copier does not have HDD and network connection.We will be grateful for any advice. Thanks.
  • tsbservice
    Field tech
    • 8043
    Re: С 287 , codes C FA17, C 40C5
    After replacing the CCD Unit, it must be calibrated, did you do it?
    • pinspin
      • Oct 2011
      • 156
      Yes
      • Woxner
        • Jul 2011
        • 852
        are you saying the hdd is missing and the network port is dead? this comes with hdd. did you use w4 firmware and special. also run the self diagnostic. but mfp could be fried
        • PTAIYAT
          • 1
          Change of flat cable and for the case of C-FA17 & C-40C5 do different firmware version update.
          • byronf
            Senior Member
            • Sep 2017
            • 109
            Hi,
            Change flat cable no.6 A7AHN12V01.
            If you haven't done this repair previously you might aswell order x2 A7AHM90000 incase the locks break.
