C558
  • andriess
    • May 2017
    • 3
    C558
    I have a bizhub c558,the machine does not print automaticaly,you have to switch the machine off and on again before it can print.Any solutions?
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: C558
    try and initialize it.
    just back up everything first.
    prolly need movie data too after.
    that where id start.
    • rickh
      • Aug 2012
      • 7
      Re: C558
      I have a C558 that has to be restarted as well. It seems that it does not wake up from sleep mode. This is an intermittent problem. Was wondering if you had any luck with yours. still working on solution for this problem.
        Re: C558
        did you try Synth's suggestions?
        • Bix
          • Apr 2018
          • 1421
          Re: C558
          It happened to me that the DF board on MFPB blew everything. Try to remove it!Alternatively change SSD
          • rickh
            • Aug 2012
            • 7
            Re: C558
            I just did that today. Customer will notify if problem reoccurs. Should know in the next few days. I did notice error code C40C5 (A CPU communication error is detected) I have a feeling its gonna be the MFP pwb.
            • drowranger
              • Jul 2015
              • 122
              Re: C558
              make sure Hard disk is on on System 2 and rip print jobs on hdd is on at utility> printer settings> basic settings
              and check if the power settings are similar to C458 Bonjour and airprint issues and the FW is latest.
