New Bizhub "i" series
  • Bix
    • Apr 2018
    • 1421
    #16
    Re: New Bizhub "i" series
    They are like tablets, you can zoom in with your fingers and there is also vibration feedback
    • rrrohan
      • Sep 2011
      • 1977
      #17
      I think marketplace button vanishes if you turn off web browser
      • copytechman
        • Nov 2008
        • 947
        #18
        Is there a simple/straighforward way of disabling the web browser function? (Not that I have found it directly yet however lol!)
        Regards!
        A.
        • rrrohan
          • Sep 2011
          • 1977
          #19
          Regards!
          A.
          Yeah it's under network settings somewhere.
          • occus
            • 337
            #20
            Originally posted by copyrooks
            We got a c250i and honestly looks like a glorified c227.
            Yes... and the print quality is the same to. Really bad. I always tell the customers we sell the mercedes benz or audi and not a indian tata (cars) so the costs are higher
            But this is the level of a oki or sharp.
            First print from a new unboxed +250i, 2/3/4 print are from the second +250i.
            On yellow it is not visible , magenta is middle but cyan is lighter and darker areas and black is totaly poor. The laser-glasses are cleaned.
            After initialize and Image Stabilisation 3x grad adjust for 600dpi and 1200dpi and copy it is a bit better. But all contract customers with a +220/+224e would call me for a rep if they see this lines.
            Also i can see white spots on prints... but i don' want change the primary transfer value out of the box for a shorter drum life.
            My question on other sellers:
            1. Are the costs for toner and drums higher to in your countrys? (for a bad quality )
            2. Do you have the same expirience whit this low level maschines?
            Thank you for your feedback.
            • Max
              • Oct 2011
              • 561
              #21
              Hi. Is there a way to make a classic screen as default by any chance? (copy) Don't like the basic one at all. Also can't seam to find a way to print a test page as before. Is that no longer possible?
              Thank you.
              • occus
                • 337
                #22
                Thank you.
                Yes it is... utility\administrator\system settings\ scroll down to def.operation.setting >classic or the new one
                In this case the second what i recomand is to change the soft menu buttons on the right side for quick acces copy and scan (help and zoom is not needet but to copy and scan)
                And the last is to set the copy screen from basic to quick copy >utility>utility>costumize
                • copyrooks
                  • Oct 2013
                  • 210
                  #23
                  Regards!
                  A.
                  Answer
                  The MarketPlace Application can be hidden by preforming the following steps.
                  1. Select Utiliy
                  2. Select Administrator Mode
                  3. Select Network
                  4. Select IWS Settings
                  5. Select MarketPlace Settings
                  6. Select Enable settings (OFF)
                  Note: The MarketPlace buttons will be hidden in the Basic Style Menu and The Classic Style Menu.
                  Supposedly turning this off can remedy some issues with the copier unable to boot.
                  • Max
                    • Oct 2011
                    • 561
                    #24
                    I found the soft keys and replaces them. Thank you for the rest.
                    • 1ERIMPRESSIONB
                      • Dec 2019
                      • 8
                      #25
                      [ATTACH=CONFIG]43311[/ATTACH][ATTACH=CONFIG]43312[/ATTACH][ATTACH=CONFIG]43311[/ATTACH][ATTACH=CONFIG]43313[/ATTACH]
                      HELLO ,
                      i recently receive 10 250i konica minolta and i have the same problem : poor density on the black principally .
                      have you found any issue ?
                      thanks
                      • korthr5
                        • Feb 2016
                        • 39
                        #26
                        Hello
                        In Portugal yes.
                        Machine more expensive.
                        Bad quality and white spots.
                        More fragil plastics.
                        And toner, and drum more expensive.
                        • sushil
                          • Aug 2019
                          • 1
                          #27
                          For Black density switch to following settings
                          1) 2nd Transfer = -3
                          2) Fusing transport speed = +15
                          3) Fusing Temp = +10
                          • occus
                            • 337
                            #28
                            Originally posted by 1ERIMPRESSIONB
                            HELLO ,
                            thanks
                            I have received the information that you have to update to firmware 75 and make the stabilisation and gradation adjust. It is important to make this again after the update.
                            And yes it seems to me that i have now the print quality of a 258.
                            • occus
                              • 337
                              #29
                              GC1-75 is available. Fixes for standby/sleep and bootup time problems.
                              • Bix
                                • Apr 2018
                                • 1421
                                #30
                                Since G00-75, there have been quality corrections. Perform an Image Processing Adjustment and update the drivers.
                                Although, since the life of the consumables is increased, I imagine why it will use less toner
