C-1105
  • emujo2
    • Mar 2017
    • 1579
    [Error Code] C-1105
    Have a tech troubleshooting C-1105 error on C458..(FS-536). After numerous trips he swapped finisher with another C458...C-1105 did not travel with problem finisher, but popped on original MFP..Not causing codes on other MFP. Any ideas on what, outside of the eject arms, could be causing this code? TIA E
  • tsbservice
    Field tech
    • 8007
    Re: C-1105
    Have no idea, but I would update FW...just in case.
    • Woxner
      • Jul 2011
      • 848
      Re: C-1105
      this is a firmware bug on the 8 series. it has been correct in latest fw. do the base and the special
      • emujo2
        • Mar 2017
        • 1579
        Re: C-1105
        I do not see anything about this error in the base or special w5 f/w..Can you be a little more specific? Thanks
        • tsbservice
          Field tech
          • 8007
          Re: C-1105
          Any news on this?
