Fiery X3eTY2 65C-KM Scan to FTP set up
  • joe.m1989
    • Apr 2018
    • 14
    So I'm having some hell trying to get this person's scanner back up and running. I'd like to get it set up to scan via FTP, and I would like to ideally use the konica's FTP utility. When I go to set up scanning, it wants the file path, and under the manual, its just showing "input a file path of the FTP server." Well, the konica's ftp utility does that for me. Do I still need to specify the path without it? Because without the path, its not working. Below is a link to the manual in which is shows vaguely what to put in for the file path. Fiery X3eTY2 65C-KM User Manual (Page 52 of 101)
    Scan to SMB isn't working for some reason, but I chocked it up to typical Windows 10 and not being friendly with SMB
  • Synthohol
    Certified Konica Expert
    • 5835
    Re: Fiery X3eTY2 65C-KM Scan to FTP set up
    just scan to the fiery HDD and the users can download the scans from the fiery webpage.
    you can even add a 2nd HDD make share folders and map the drive to users.
    just RDC into the fiery and set it all up. 10 minutes work really.
      • 14754
      Anytime I have set up FTP scanning I have simply used a forward slash / as the file path
