KM bizhub C224e blank print/copy
  • tsbservice
    Field tech
    • 8020
    This machine has over million prints, all consumables are changed as per service recommendations. There is magnetic brush on K dev unit.
    Blank copies/prints are ONLY in black mode. I mean only K is missing. Read about HVT failure when ALL 4 colors are missing.
    I'm going to open PWB box to see if the Developing solenoid (SD4) is stuck(machine is in dirty environment) and K developer unit drive. Next maybe PH unit but I doubt about it gone bad.
    Any other ideas Ladies and Gents?
    TIA
  • Toxic
    • 698
    Re: KM bizhub C224e blank print/copy
    Good plan, i would do the same.
    I assume you check/replace drum first.
    • tsbservice
      Field tech
      • 8020
      Yeah, drum was first. Ended up with cleaning Developing solenoid (SD4) and taping it with piece of scotch - to prevent sticking.
      No more blank K prints since then. I will order SD4 (
      A161M20300 Flapper solenoid) and replace it just in case.
      Thanks for replying Toxic.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        I didn't even know there was a solenoid for that. WTH were the engineers thinking on that one!!? One of the main failure points of copiers/printers is solenoids (more so) and clutches. If you have access to mykonicaminolta.com, you should submit that for one of the solutions (didn't see it listed yet).
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
