BIZHUB 1050
  • fernan
    • Jan 2008
    • 61
    BIZHUB 1050
    hello guys,,,
    Can anyone help on Konicaminolta BH 1050 frequent jamming when paper is coming out FACE DOWN but no jamming occur DOUBLE SIDED COPY and COPY FACE UP,
    i use to set the machine on double sided as a default,
    any one has an idea about it ?
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Did this start after a PM? If so check decurling roller bearings. I made the mistake on my first PM of throwing out one of the bearings on the decurling roller it came out with the roller and i didn't realize there was more than 1 bearing on each end. It caused the symptom you are describing. I learned from my mistake.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • fernan
      • Jan 2008
      • 61
      thanks a lot.......
      • Rolandito
        • Aug 2007
        • 91
        maybe u must clean photo sensors, where the sheets is turn over unit,
        • fernan
          • Jan 2008
          • 61
          i finally solved the problem THANKS
