C224e staple message but no finisher ???
  • copyman
    Owner / Technician
    • Sep 2005
    • 4787
    C224e just delivered from wholesaler. Has a message "staple cannot be used" but has no finisher. It does look like a FS-533 inner finisher was removed.
    Anyway to get rid of that message? As a last resort I have a FS-534 I can attached to see if message goes away.
    Thanks in advance
  • tsbservice
    Field tech
    • 8076
    Re: C224e staple message but no finisher ???
    I would check in service mode that this option serial number is cleared. Also may try trouble isolating finisher maybe.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4787
      Fixed. Nothing worked so ended up connecting FS-534 and updating FW. All good now
      • tsbservice
        Field tech
        • 8076
        Good for you.
        Out of curiosity I would try at first FW update without finisher, just in case when there isn't finisher available.
        • REGSIS
          • May 2016
          • 440
          Look in instalation manual, there's a sensor which is mounted on exit unit before mounting a relay unit.
          Maybe it was left on main body when finisher is removed.
