Bizhub 367 , code C-E301
  • pinspin
    • Oct 2011
    • 156
    [Error Code] Bizhub 367 , code C-E301
    Hi, our copier 367 , when scanning to the folder ONLY in the Сompact PDF mode 300 dpi gives the code C-E301. In all other modes, the scan is excellent! Reset copier, firmware update, replacing the HDD did not help. We will be grateful for any advice. Thank.
  • tsbservice
    Field tech
    • 8052
    Re: Bizhub 367 , code C-E301
    Definitely sounds FW related, as with every major FW release they(KM) claiming some type of C-E301 error fixed.
    First I would try it directly from my laptop to exclude any network related issues.
    • tsbservice
      Field tech
      • 8052
      Latest special firmware ver. GP2-W4 resolves more than 10 instances of dreaded C-E301.
      I would give it a try if not at that FW level.
      • kingarthur
        • 1385
        agree latest FW, but if you look at the management list, it tells you why the C-E301 code occurs, then look at the read me file for the FW, it will tell you which C-E301 (sub code) it fixes, I've started to compile a list of C-E301 errors from the FW read me list
        • samir001
          • Feb 2024
          • 13
          hi there,
          it happen to me machine model c227,
          how did it happen,after i did initialization
          how i solved it,go to service manual,then activate hdd,
          and it sorted
