Drum, Dev, Coronas replaced w/F8\F5. Week later dead cycling after first copy out. checked hopper connections all good. SM says S106 or PWBA or M9. Moter looks OK. Any experience or ideas shared would be appreciated
Minolta 3050 C0072 after Drum & Developer
my experience with a c0072 is the toner bottle not turning. make sure that the toner bottle is in correctly. also you may have to take the toner add assembly out and clean it all. make sure that the little black flag is present and the toner home position sensor is clean.
I have seen the black gear/ with the flag on it actually hogs out and does not let the bottle spin. good luck
brent
