Missing OCR Dictionary Konica Minolta C364e
  • denvertan
    • May 2019
    • 101
    Again, the machine really let me learnt a lot.
    Today I started the 3rd machine and I am greeted by the copier with this message "OCR Dictionary is missing Contact Tech Support" !
    Can someone please help me with the OCR File. Thank you.
  • tsbservice
    Field tech
    • 8081
    Re: Missing OCR Dictionary Konica Minolta C364e
    You need some options to have OCR, like i-option and memory module.
    Leave it as is, and start reading Service manual. This is not a chat.
    • emujo2
      • Mar 2017
      • 1579
      What you are showing us means nothing...You would have to check your list of enabled licenses to determine if this is a problem brought on by the LK installed w/o OCR dictionary, or some other issue. E
      • Woxner
        • Jul 2011
        • 854
        you can still put the pdf font and ocr even without those options.
        • denvertan
          • May 2019
          • 101
          Successful remove the error after check in lms.
          Alert is removed after the deactivate the i-Option. Thank you all.
          • Massimiliano
            • Oct 2019
            • 48
            Hi,
            Can you please tell me how you deactivated the i-Option?
            I have the same problem and also this " The PDF/A Font was not found.
            Thank you
