VOIP and Fax
  • rrrohan
    • Sep 2011
    • 1977
    VOIP and Fax
    I have a customer using a Cisco VOIP box for fax line to connect to from copier.
    Trying to do all the adjustments but they dont seem to make it any worse or any better.
    Another tech told me that he beleives no adjustments made on copier will help and all the adjustments are made on the VOIP box itself.
    Is this true?
  • BaconSteve
    • Apr 2019
    • 140
    • adecanmin
      • Oct 2010
      • 298
      Re: VOIP and Fax
      I've been having issues with VOIP as well. I've had to replace copiers because i could not get the machine to work properly. It is definitely hit or miss. Faxing is on the way out. Just a few more years of hassle.
      • copyrooks
        • Oct 2013
        • 208
        Re: VOIP and Fax
        You can try this
