BHC353 IU313 image units
  • Desert Rat
    • May 2008
    • 1089
    I think I know the answer but I have to be sure.
    My customer needs to have the color IU's replaced. I am looking at the OCE equivalent (CM3522 I think) IU's.
    I believe all I would need to do is replace the chips?
    Correct?
    DR
  • copyman
    Owner / Technician
    • Sep 2005
    • 4702
    Re: BHC353 IU313 image units
    yes I believe that is all needed. As you probably know but I'll post for others, the C203/253 and C353 IU's are different, you can interchange but may have to swap end cap or cut fins, etc. Most chips I see are interchangeable for all 3 models and all the other OEM equivalents. As these machines are getting older and no longer supported there's going to be a lot of swapping going on!
    Correct?
    DR
    • Desert Rat
      • May 2008
      • 1089
      Copyman,
      Thank you for that post. I hadn't thought about using the 203/253 drum units in the 353. Now that I know, I'm glad I did not buy
      at the higher price. So I need to go shopping online again.
      As an Indy, this will be very helpful.
      Thanks a bunch
      DR
