Remove iSeries password change request
  • Bix
    • Apr 2018
    • 1421
    Hello,
    whenever I turn on the C360i printer, it asks me to change the default password.
    Any suggestions to keep the default password without the notice to change passwords coming out?
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Remove iSeries password change request
    what was done previously? was it firmware?
    there is a bulletin that after a certain firmware the HDD gets 'uninstalled'
    maybe thats the culprit?
    • REGSIS
      • May 2016
      • 440
      Originally posted by Bix
      Hello,
      Admin settings -> security settings. In this menu click on first item on top of menu, on the right side scroll down (to middle aproximately) and disable the option to warn you abot the password rules at every boot.
      P.S. when you boot machine and warning pop up press ok and it will open that menu directly.
      • tsbservice
        Field tech
        • 8080
        That would be the right answer.
        • Bix
          • Apr 2018
          • 1421
          Hi I thank you but today I could not find this option.
          I went to admin> security and I found the PKI configuration.
          • tsbservice
            Field tech
            • 8080
            Descriptions of Functions / Utility Keys
            Try to set Security Warning Display Setting - OFF
            • Bix
              • Apr 2018
              • 1421
              hi thank you! This seems to work
