Tray 2 C4050i
  • Bix
    • Apr 2018
    • 1421
    Tray 2 C4050i
    Hi, I installed a c4050i with an additional tray
    It is a PF-P20. I connected the connector on the left but the printer does not identify it
    Do you need to enable something from Service Mode?
    Thank you
    • 23010
    Re: Tray 2 C4050i
    Did you turn off and unplug the machine before installing the accessory? =^..^=
    • Bix
      • Apr 2018
      • 1421
      Re: Tray 2 C4050i
      of course! I tried to disconnect and reconnect. I restarted several times
      • rrrohan
        • Sep 2011
        • 1977
        Re: Tray 2 C4050i
        manual just says plug it in and make sure you dont pinch the wires.
        • tsbservice
          Field tech
          • 8042
          Re: Tray 2 C4050i
          Thank you
          I think you're installed wrong option. Check your product specs, you need PF-P21.
          • Bix
            • Apr 2018
            • 1421
            Re: Tray 2 C4050i
            I finally managed to recover the installation manual for PF-P20. Unfortunately those who installed it threw it away.
            it is compatible with C4050i, c3350I, c3320i, C4000i and C3300i.
            I think I understood the reason. This is pretty stupid but being new cars, I didn't think. The cable was connected in the connector of the drawer (I thought it was the connector coming from the printer but in reality it is the drawer). In theory I will have to remove the back cover and connect it to the machine.
            I'll try
