c258 dumping yell dev
  • seriches
    • Nov 2016
    • 10
    [Misc] c258 dumping yell dev
    have a c258 first print out demo page or test copy is fine, after a run about 10 mc starts haveing yell wash in background and yell dev is the depleated tottaly empty
    any ideas
    tried drum new
    dev unit new
    td also new
    ram dumped the mc firmware all done
    steve r
  • tsbservice
    Field tech
    • 8028
    Re: c258 dumping yell dev
    Check ALL consumables(Drums, devs, TB) and replace all that is overdue not just yellow.
    There is known issue when HV is arcing so you may also check all contacts.
    Lastly make sure your filters are not clogged.
    • seriches
      • Nov 2016
      • 10
      thanks yes all 4 devs new and 4 drums but still same very weird fault as i said turn mc of on ie reboot image is perfect try and do a run a no go checked all conectors will try hvt
