C-D0E1 (3), Error -2 while formatting new disks, Bizhub C1060
  • Froota
    Field service tech.
    • 129
    [Error Code] C-D0E1 (3), Error -2 while formatting new disks, Bizhub C1060
    Hi you all,
    Customer called concerning an error message C-D0E1(3) on a Bizhub C1060, with a Fiery controller. My colleague made a data format as the machine doesn't use the 3 HDD's because the use of an external controller. The error came back the day after, wherefore I replaced the 3 HDD's and tried to make a format. (Dipswitch 36-6 = 0, Dipswitch 40-7= 0)
    The device recognizes the 3 drives but just sees 465gig of the 3x500gig. Appr. 20sec. after selecting the start button to format, the device gives error -2, apparantly something with dipswitches (are correct), connection of HDD (is fine) or HDD replacement (drives are new).
    Reconnecting the 3 old drives gives the same result......Anyone?
    gr,
    Froota
  • Froota
    Field service tech.
    • 129
    Re: C-D0E1 (3), Error -2 while formatting new disks, Bizhub C1060
    Forgot to mention, I replaced the overall control board today, same problem.....
      • 23009
      Sorry, I've not seen this, but will be interested in what you find. =^..^=
      • Walterj
        KONICA MINOLTA
        • Jun 2017
        • 89
        Originally posted by Froota
        Hi you all,
        gr,
        Froota
        good day
        Dear
        I recommend you check the DIPSW 18-7
        Execute bad sectors check and recovery in the output check I/O 99-03.
        Regards
        • Froota
          Field service tech.
          • 129
          Originally posted by Walterj
          good day
          Dear
          Regards
          Hi,
          Thx for the feedback,
          Dipsw 18-7 is a faulty part isolation, correct? Isn't this likely the same as the 99-03, where both functions gives the information if there's a bad sector or not?
          I didn't had some errors on the bad sector test, but the format didn't went well. Today I have had another machine with the same story but there I had some bad sectors and will replace the HDD's before going further.
          • rhabibp
            • Feb 2023
            • 1
            Hi, did you got the solution of it?
