Bizhub c3850fs airprint button missing?
  • mrfuser
    • 1617
    anyone know the trick to turn on airprint? I have upgraded to the latest firmware and it still does not show up.
    Thanks all!
    K
  • copyrooks
    • Oct 2013
    • 208
    Re: Bizhub c3850fs airprint button missing?
    CAUSE: Incorrect software switch settings
    SOLUTION: Perform the following procedure:
    1. Enter Service Mode
    2. Select System 2
    3. Select Software Switch Settings
    4. Select Sw 13
    5. Change setting to HEX 04, press OK and select Fix
    6. Cycle the power on the machine and now the AirPrint button should be available to select
    • mrfuser
      • 1617
      Yep been there done that. Still no AirPrint button.
      2. Select System 2
      4. Select Sw 13
      • mincopier
        • Dec 2015
        • 289
        Firmware 30G0-515 or later Dipswitch 168 needs to be set to Hex 00 to Enable AirPrint or Hex 08 to Disable AirPrint
        Firmware 30G0-607 or later AirPrint should be enabled automatically.
        This is what I got from Konicaminolta's spreadsheet
        • mrfuser
          • 1617
          I had to upgrade controller fw one more step
          • rrrohan
            • Sep 2011
            • 1976
            so glad the C3350i doesnt have separate firmware files to load.
