Konica Minolta C454 C9404
  • mearmi
    • Oct 2010
    • 350
    Konica Minolta c454 throws c94-04
    doest it need the firmware to be updated?
    if someone can advise what is the latest firmware and share it. Will be great help.
    mearmi@hotmail.com
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: Konica Minolta C454 C9404
    check your PMs fellow contributor
    • Walterj
      KONICA MINOLTA
      • Jun 2017
      • 89
      mearmi@hotmail.com
      good day
      Dear
      You tried to reset the error code as follows
      System1 -> Initialization -> System Error Clear
      Check the harness connection between the CIS and Dual scan image processing board (DSIPB). Then check between CIS and CIS Power Supply (CISPU).
      Replace the CIS and check for reoccurring error.
      Replace the CISPU if either fuse is OPEN and check for reoccurring error.
      Check the following fuses on the CIS Power Supply (CISPU).
      F1 - For 12V DC
      If OPEN, replace the CISPU.
      F2 - For 5V DC
      If all of the above is good
      Update the base fw (G00-K5)
      Or the special fw (GC1-K2)
      Regards
      Luck
      • mearmi
        • Oct 2010
        • 350
        Originally posted by Walterj
        good day
        Dear
        F1 - For 12V DC
        F2 - For 5V DC
        Regards
        Luck
        Can I get FW GC1-K2 and does it support gmail?
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          good day
          Dear
          write to me in private
          Regards
