C8000 / V60-ish fw / 4M+ copies
I need some help troubleshooting code C-C101 no response from PRCB to OACB.
The code occurred while the customer was using the machine not during or immediately after servicing.
I have replaced the OACB & PRCB simultaneously after checking the OACB to PRCB wire harness for continuity & checking for shorts to ground (per KM resolution).
I have looked at other exposed harnesses as best possible too.
I reflashed fw except for PRCB - there is no power on any of the power pins so that one fails.
(Both ADU & Process carriage were pulled out / disconnected to eliminate them as points of failure)
The service manual is not clear on whether or not the PRCB should have 5V ( or other V's) before SW2 turns on but SW2 (which connects to the PRCB) does initiate the startup process.
OACB (& the other boards on the left side) are getting 5V from DCPS/1 but no Voltages are detected that go to the PRCB power pins.
My question is: should there be any Voltages on the PRCB power pins (CN131 & 132 on the right side) when the main switch is on but sub switch SW2 still off.
If there should be then I will assume a DCPS/1 issue. (I am currently trying to locate a DCPS/1 to test.)
