New Konica minolta pro 1100 error C-0001
  • Muller87
    • Sep 2019
    • 2
    [Error Code] New Konica minolta pro 1100 error C-0001
    Hi All.
    I installed a new pro 1100 with the following option: LU-412. The machine is giving me an error code C-0001. I did the firmware and checked all connections, but still gives the same code. Any ideas please?
    Kind regards.
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: New Konica minolta pro 1100 error C-0001
    try basic troubleshooting, disconnect all accessories and make a copy. then reattach 1 accessory at a time and try again.
    thats some communication error like a connector is not in all the way or maybe pinched.
    also refer to the accessory install guide in case there is a jumper somewhere that needs to be changed.
    KM has a loopback jumper on some finishers and maybe on the prcb, i dont remember but at least narrow it down the part that is causing the communication error.
    good luck.
    • Muller87
      • Sep 2019
      • 2
      Thank you.
      Will check installation manuals again and run through all option. Must be something I missed.
      Will let you know.
      Kind regards
