Re: Bizhub 4050 freezes/locking up
I had a bad control panel just 2 weeks ago on a 4050 that did basically the same thing. Randomly froze up. Replacing it fixed the problem.
We tried this same group of machines on a couple of different networks without an issue. No other MFP make/model had the issue.
Konica Minolta bizhub 475 error code E301
=^..^=Leave a comment:
Better consult with your manual.Leave a comment:
Hi All, as title say I have machine that freezes yesterday and today again. Yesterday I was in a rush for other calls so just jumped in to see what happens.
Sure machine had no responding to any commands/touches/buttons and was completely locked. As a side note they have YSoft SafeQ installed on this.
I have to restart it and pulled power cable, they claimed to did that twice via power switch. After that machine comes to life I checked all operation, checked error history only few of dreaded C-E301 but last one was days ago. Today they called back, while on the phone I asked them to do restart and machine revived again.
I definitely think that have to come back sooner than later with some solutions in mind. For now my plan is to calibrate control panel and do FW update, maybe do HDD format.
Any other ideas will be much appreciated.Leave a comment:
For the moment HDD format looks to do the job.Leave a comment:
From what I'm reading it would be FW issue, especially FW MR7 copes with two situations with locked up machine. Will let you know guys.Leave a comment:
We had a couple that kept locking up. Pulled the network line and it would copy. No one could figure it out. Went on for months and finally installed 2 different models. Put these elsewhere and they are working.Leave a comment:
It should be a firmware problem.
A few days ago I read a note on C-E301 and SafeQ installed.Leave a comment:
may also be the fax unit or something on the network causing it to lock up.Leave a comment:
