Bizhub 308 does not start printing before receiving all pages of original file
  • Takhnamishvili
    • Mar 2019
    • 53
    Hi all,
    Have a strange problem on Bizhub 308. When I want to print for example some document with a number of pages, MFP starts receiving document but does not start printing before all pages are received, only after receiving all of them, it starts printing. Any opinions or suggestions?
    Thanks in advance..
  • kingarthur
    • 1332
    Re: Bizhub 308 does not start printing before receiving all pages of original file
    go to the printer driver properties, go to advanced it's probably set to "start printing after last page is spooled"
    • Takhnamishvili
      • Mar 2019
      • 53
      I checked, it's set to "Start Printing Immediately"
        • 29936
        Please provide more details what driver? what port ?
        should be set to print by ipaddress NOT a WSD port
        should be using a pcl driver downloaded from Konica
        • Takhnamishvili
          • Mar 2019
          • 53
          PCL driver, downloaded from Konicaminolta.eu
          Network port, printing by ip address.
          P.S. PCL and PS driver gave same result. Also Win 10 and Win 7 gives no difference.
          • Bix
            • Apr 2018
            • 1421
            Hi, it's a problem that often happened to me.
            I solved this by setting up:
            1. Printing Preferences> Quality> Font Type Setting: Image. Also remove "use printer characters" flag.
            2. Printing Preferences> Finishing> Paper Layout: Productivity Priority.
            3. Disable two-way communication
            • Takhnamishvili
              • Mar 2019
              • 53
              Thanks, I'll try and let you know how it goes )
              • tech51
                • 846
                • Takhnamishvili
                  • Mar 2019
                  • 53
                  Today I tried these settings and MFP started printing normally, without waiting. Thank you!
                  • Bix
                    • Apr 2018
                    • 1421
                    You are welcome!
