Bizhub C200 scan to SMB
  • lebo
    • Aug 2012
    • 88
    Hello, I can not force Scan from the Bizhub C200 through SMB to PC with Windows 10.
    Any Idea ?
    Login, Password, name of shared folder as well as IP adresse of PC are all set OK
    PC is in Private network profile with sharing folders ON
    SMB server/client ver 1.0 is "ON" on that Windows PC
    There is no Antivir with firewall installed on that PC
    Bizhub C200 and PC are in the same workgroup.
    Scan error: EE09C7
    And I am frustrated :-(
    Thank you for your advices.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    • tsbservice
      Field tech
      • 8064
      Re: Bizhub C200 scan to SMB
      You can do it but have to update FW to Ver. G00-35 or later as M$ literally throw out of the Window(s) NTLMv1 authentication
      • mikeena
        Branch Technical Manager
        • Mar 2007
        • 220
        Also go Into the program files then go into feature and make sure smb 1.1 is not unchecked. New windows updates is disabling and setting 2.0 as default
        • rrrohan
          • Sep 2011
          • 1977
          im told re enabling SMB1 is a bad idea
          Id use the trusty old FTP instead
          • B0265
            • Jan 2007
            • 718
            It might be that this old model only use port 139, check that NetBIOS over Tcpip is enabled on the PC.
