BH-C-3110, CE Password
  • Hansoon
    • Sep 2007
    • 3381
    Got from a wholesaler a BH-C-3110 with only 5k on the clock. CE Password has been changed to unknown. The usual 927...... is not accepted. Cannot call up the service mode.
    Any solution please?
    Hans
    • 23006
    Re: BH-C-3110, CE Password
    I'm willing to take a gamble that the password is not changed, it's just a little more difficult to identify. I spent a good hour figuring this out. It's only a slight variation on the Konica Minolta standard:
    V x8 down arrow to Utility > Select > Stop 00 Stop 01 > * to change alpha to numeric > 92729272 >
    Select
    Are you doing firmware? It's a little strange compared to the usual Konica Minolta way. I'll attach the document:
    • Hansoon
      • Sep 2007
      • 3381
      Thanks Cat. Yes, I am aware of that Alphanumeric issue and took care of it from the beginning, but no way.
      Hans
      • allan
        RTFM!!
        • 5462
        Whats wrong with it? O forgot its a toner chewing faulty thing.
        Whatever
        • Hansoon
          • Sep 2007
          • 3381
          Its not accepting a new K-Toner cartridge. Did all the usual, terminals, harness etc.
          Hans
          • tsbservice
            Field tech
            • 8007
            You can try Engine DIPSW 28, that will execute forcibly new release of a toner cartridge...in case toner chip is bad.
