Bizhub C258 Issue: error-code: c5501
  • Copier repairman
    • Aug 2019
    • 86
    [Error Code] Bizhub C258 Issue: error-code: c5501
    Ask for help.
    Model Name: Bizhub C258
    Description:
    AC signal abnormality.
    The zero cross signal is not input during fusing phase control.
    Check: No abnormality in DCPU.
    No fuser failure.
    MFPB intermittently available.
    Is there a workaround with the firmware?
  • tsbservice
    Field tech
    • 8053
    Re: Bizhub C258 Issue: error-code: c5501
    FW does not look as resolution in your case.
    Replace in that order:
    1. Fuser
    2. Power supply
    3. MFPB
    • Copier repairman
      • Aug 2019
      • 86
      1. Fuser
      2. Power supply
      3. MFPB
      If you move the MFPB of another device of the same model and install it, it works fine.
        then it sounds like PS or harnesses
          • 23010
          Search: zero-cross error
