C252 SMB/FTP/Email scans say Job has been done improperly check log: server connect
  • captainrva
    • Oct 2014
    • 100
    I have a C252 and no matter what scans protocol you use, it says Job has been done improperly with a server connection error. I tried to re-flash the firmware with same FW but I got an error that the card was invalid. I tried to upgrade the FW and got the same error so I then tried to update/re-flash via ISW and it downloaded the FW but then gave and error "Failed to get information from the FW server". I tried to set up new one touches and they failed too. Changed the SMTP from the clients to a gmail and it failed again. I can print to the machine and make copies, just can't scan. Also, I can't log in to the Webconnection as admin because the machine will freeze and the browser just stays blank on all browsers (IE, Chrome, Opera, Firefox)
    Any help is appreciated.
  • Bix
    • Apr 2018
    • 1421
    Re: C252 SMB/FTP/Email scans say Job has been done improperly check log: server conne
    Have you tried connecting directly with your PC? (SMB test)
    Maybe there's something blocking the port
      • 30086
      You need to troubleshoot server connection error.
      Dns issue gateway issue etc...
      • captainrva
        • Oct 2014
        • 100
        I directly connnected with pc and got the same error and still couldn't see Web Connection . Their network DNS and Gateway is just 192.168.1.1.
        • tsbservice
          Field tech
          • 8002
          Go to service mode and check the state of machine HDD, you may be surprised.
          • copier tech
            • 8136
            This is a very old model long been discontinued forget getting this to scan via gmail or any of the big players, gmail, O365 etc.
            If you have an old Win XP or 7 PC set up a scan folder to this & share of the network.
            Your FW update failed try another CF card they were fussy on what CF cards worked even when new.
            Personally I wouldn't waste my time on this old box
