Konica Minolta C360i, Turn on consumables
  • Thayer
    • Dec 2017
    • 107
    [Misc] Konica Minolta C360i, Turn on consumables
    Hello
    Currently setting up new machine, and want to turn the consumables on.
    I changed the dip switch 227 & 230 to correct numbers, still don't see consumables.
    Can any one help with this?
    THanks
  • tsbservice
    Field tech
    • 8008
    Re: Konica Minolta C360i, Turn on consumables
    Originally posted by Thayer
    Hello
    THanks
    Did you restart the machine after changing soft switches? From where they are missing- control panel, web page?
      • 23007
      Its convenient to see them from the Utility Menu, but you can always see them on the Management List. =^..^=
      • Jjg
        • Oct 2019
        • 1
        After setting dip switch 227 to hex 0, go to the main screen of the copier. Touch utility, then may need utility again, then information, then device information, then consumables. you should be able to print the list out from here or just scroll through it. If you do not have the switch set right you will just see the toner life not the other consumables.
        • Thayer
          • Dec 2017
          • 107
          Yes, i restarted machine after changing soft switches. Missing from control panel, Certain techs would like it turned back on.
          They are being a pain....
          • rrrohan
            • Sep 2011
            • 1977
            seems like Japan, North America and Europe default to Do not Display
            • Thayer
              • Dec 2017
              • 107
              That's where it's was, thanks!
