KM FS-607 too much loop after conv roller 4, causing back edge flick
  • raplma
    • Mar 2017
    • 140
    All, this one has me foxed, so would appreciate any suggestions.
    FS-607 on KM5501, 3.3Mill finisher regularly cleaned and service parts within date.
    If you are able to watch the short video clip below, you'll notice that as the sheet passes through conveyance roller 4, the back edge of the paper is flicking up, as the roller accelerates.
    Curl adjustment has little effect and in any case if I remember correctly, that controls the speed differential between the c5501 exit rollers and finisher entrance rollers - hence loop production - rather than the side in question.
    It is doing it on all lighter weight materials, the material being used is 130gsm, SRA4 coated gloss, and a quality paper.
    The only thought that comes to mind is that the surface of the roller is causing adherence of the material??
    More info: the observant will notice that there is the loom for the punch present. I noticed that the punch was jumping, so removed it and replaced it with the standard conveyance plate from a dead finisher.
    However having done so I now know the jumping wasn't due to the punch but rather the 'flicking' of the back edge.
    Any thoughts most welcome
  • tsbservice
    Field tech
    • 7635
    Re: KM FS-607 too much loop after conv roller 4, causing back edge flick
    Any paper jam code could be pertinent.
    • raplma
      • Mar 2017
      • 140
      Totally agree, however there is no jam, it will happily run like this, it does not affect the functionality of the machine, so doesn't code out, it just curls the back end of the sheet like scissors curl a ribbon.
      • tsbservice
        Field tech
        • 7635
        OK, any Mylar put on there or missing to prevent this? Must to admit,
        I'm not familiar with this model at all, just working with you.
        • raplma
          • Mar 2017
          • 140
          Indeed, your thoughts are most welcome.
          The mylar guides are all present and in good condition. The conveyance roller underneath the grey one you see is in good order too, as are the mylar guides on the black plastic assembly it sits in. And certainly on other machines i have seen these guides well worn down, but on this finisher they are good. The lower roller is also sprung and this moves freely, so the tension between the rollers should be ok.
          From your experience, could it be the grey roller has lost it's coating? Assuming it could be coated?? It is 9 years old, and from my litho days the surface of a roller is critical.
          • Toxic
            • 690
            Have that problem few times on C5501.
            Paper come out ok but curly.
            Problem solved replacing 13QE45132 CONVEYANCE ROLLER 3
            Rubber rollers on the shaft gets lower diameter than normal and can not provide same paper speed like rollers before them and that is why paper go up and curly.
            If i remember good,if half open CONVEYANCE GUIDE PLATE 5 while machine working thats disengage contact this problematic rollers on shaft with paper and paper go straight then like it should.
              • 22705
              That was my theory right there. The reduced roller diameter would decelerate the paper. I don't know how much disassembly is required for this part of the machine, but I use a paper strip wrapped around the roller, then make a mark to determine the circumference. =^..^=
              • raplma
                • Mar 2017
                • 140
                Many thanks for this, makes perfect sense, will try this out and report back.
                Thanks again
                • tsbservice
                  Field tech
                  • 7635
                  They changed that roller also, new one is: 13QE45133E Conveyance Roller /3
                  Good call Toxic!
                  • raplma
                    • Mar 2017
                    • 140
                    Once again I doff my cap to you, you're spot on
                    See the video below, placing a pad block behind plate 5 to take the pressure it exerts on roller 3 off, and indeed no curling, no flicking.
                    I've put an order in for the roller and indeed does not look the easiest to instal, but should be ok
                    Thanks again
                    Mark
                    • Toxic
                      • 690
                      First time i see this it was hard to figure out what is problem and i have to do it myself and take some time.
                      Glad to help you to not lose time like me years ago.
                      And yes,order new part number,i take part number quickly from PM and it is obsolete.
                      Replacing procedure is little tricky but you can do it,its hard to explain this way and English is not my primary language.
                      Thanks for thanks
                      • raplma
                        • Mar 2017
                        • 140
                        Indeed, which is why I am most grateful for your help and advice.
                        As well as the help and advice of the 'collective' in this forum and endeavour not to take it for granted and support/contribute to it.
                        I'm quite happy taking things apart, in fact any machine or finisher that comes to end of life and hangs around too long soon becomes the subject of disassembly down to the screws.
                        Always the best way to get to know a unit. I don't quite count the screws, but do keep a few trays of potential spares.
                        • raplma
                          • Mar 2017
                          • 140
                          Thought I'd update the thread to complete the solution in case someone needs this in future.
                          New roller arrived today - KM had fun locating it though in the end had to send over the page from the parts manual - lol, probably miss-filed in their huge warehouse of spares.
                          To confirm P/N is 13QE45133E the revised version.
                          Having got the new one I measured the diameter of the old rollers nominally 23.2mm, diameter of new roller nominally 25.4mm, so the numbers speak for themselves. For the record old roller had done 3.6M clicks.
                          Installation was relatively straight forward especially as this is a part not designed to be replaced in the PM cycles.
                          Removed gate 5, two plastic circlips, two plastic bushes, unload springs, gate pops out
                          Released belt tension on gears by removing the gear from conv roller /2 first - simply as access was easier.
                          Removed 2 gears, gear pin, circlip & bearing from back, and knob/circlip/bearing from front and roller dropped out easily
                          Install was reverse.
                          One point of note there is no longer a groove for the rear circlip
                          So once again I doff my cap to you all especially to Toxic for the specific solution that solved our problem.
                          • tsbservice
                            Field tech
                            • 7635
                            Good job Mark!
                            Thank you for confirming solution of Toxic. Have a great weekend.
                            • Toxic
                              • 690
                              I am glad you manage to replace shaft with rollers so easy and solve the problem.
                              Thank you for feedback and detailed work description, i would not know how to explain like that on English.
