C364e - MFP firmware update N.G
Re: C364e - MFP firmware update N.G
The firmware hasn't sorted the issueits just download N.G. all the time, i then try the firmware reset which gets rid of the error invalid external device. but as soon as you try to print ANYTHING it comes up with a C-E301 error.
do you have any more suggestion or am i going to have to order a SSDBComment
IMG_2220.JPGKM had a bulletin for that problem. Follow these instructions in order and it may fix your problem. Doing this procedure has fixed a lot of weird problems with these E series machines for me. BE SURE TO EXPORT AND SAVE ALL OF YOUR IMPORTANT INFO LIKE USER CODES, SCANNING ADDRESSES, ETC. When you do these formats and data clear, it will wipe out that info.Last edited by SAR; 10-23-2019, 05:10 PM.Comment
Hi
I was having a similar problem and found this post very helpful.
Konica BH C654e reset HDD lock password issue
You may not have the HDD Lock error, but our main issue was MFP NG. Which it seems to have fixed.Everything that has a beginning, has an end.....Comment
I saved this from another post on here - have you tried this?
MF222 Etc MFP Board NG.jpgEverything that has a beginning, has an end.....Comment
Also SSD replacement..TIB08-807129-08_ENG SSD BOARD” REPLACEMENT PROCEDURE MF362Plus_.pdfEverything that has a beginning, has an end.....Comment
