C364e - MFP firmware update N.G
  • Kenny
    • Jun 2009
    • 526
    Hi guys,
    we currently have a C364e on site at a customers that wont update firmware for the MFP. Will update everything else. I have made sure the 'machine' and 'type' information is correct.
    I have tried using a used MFP for testing purposes but still comes up with the N.G error when trying to update firmware. I have tried using x3 USB sticks and also tried re-downloading the firmware to rule out it being corrupted.
    Will this mean that the SSD board has gone bad or?
    any suggestions would be a massive help.
  • mo0651
    • 1054
    Re: C364e - MFP firmware update N.G
    Just checking to see if you attempted just the MFP board by itself, by unselecting all the other FW options.
    • copier tech
      • 8142
      Originally posted by Kenny
      Hi guys,
      Are you trying to resolve a fault by updating the firmware or is the machine functioning normally?
      • tsbservice
        Field tech
        • 8007
        Try to update with HDD disconnected from MFPB.
        • Kenny
          • Jun 2009
          • 526
          Yes I have tried selecting that on its on own but no avail
          • Kenny
            • Jun 2009
            • 526
            The machine was getting 99-01 jams and saying select the correct paper in paper tray so I wanted to update firmware before anything
            • Kenny
              • Jun 2009
              • 526
              I have tried that unfortunately, the machines being abit of a nightmare haha 🤣
              • Bix
                • Apr 2018
                • 1421
                Hi Kenny, what firmware are you trying to update? I had a similar problem with a C364e. I had to disconnect the Job Separator and oddly it worked.
                Try to disconnect DF, FAX, additional trays etc.
                • Kenny
                  • Jun 2009
                  • 526
                  I am trying to update it to the latest one GDL-M1 and I will give that a go. Fingers crossed it works!!
                  • Kenny
                    • Jun 2009
                    • 526
                    Right guys I am currently on site, I have disconnected everything and tried to update firmware but still no avail. Would that mean the SSDB has gone bad?
                    • Synthohol
                      Certified Konica Expert
                      • 5822
                      why are you not using G20-M1
                      why special FW instead of base?
                      • Kenny
                        • Jun 2009
                        • 526
                        Did not know the GDL-M1 firmware was a special firmware?
                        its just the firmware that said it was the latest on the konica website.
                        • Synthohol
                          • 5822
                          thats special FW not base.\special FW is written to solve special problems.
                          try the real base FW G20-M1
                          latest does not make it the best, use the White House as an example.
                          • Kenny
                            • Jun 2009
                            • 526
                            I don't suppose you have G20-M1 firmware on hand do you? cannot seem to find that firmware
                            • Synthohol
                              • 5822
                              link sent via PM.
                              thanks for being a contributor.
