Ineo+ 3350 low density
  • DonPedro
    • Feb 2019
    • 14
    [CQ] Ineo+ 3350 low density
    Hi. I have problem with density after a few printouts. When I open and close side door everything is ok for short period. Can't enter service mode because CE pass is changed. Previous service probably changed CE.
    Any suggestion?
    Thanks for help
  • tsbservice
    Field tech
    • 8031
    Re: Ineo+ 3350 low density
    Did you clean PH windows with cleaning tool? Those can be buried with toner.
    • Bix
      • Apr 2018
      • 1421
      Hi, I suggest you share more information like the counter, consumables status, demo page ...
      • allan
        RTFM!!
        • 5462
        So the transfer roller looses pressure or electrical contact?
        Whatever
        • mo0651
          • 1054
          We did have one machine that the door ground contacts were causing this intermittent issue.
