Konica Minolta Bizhub C754. Paper Cassette Tray 3 jams
  • Alex1
    • Oct 2012
    • 285
    Hi all,
    I have been working on a Bizhub C754 and I cant get anymore then 2- 3 from the tray 3 LCF, tray 4 prints perfect tray 3 isn't. I have changed the rollers, cleaned all sensors, cleaned feed rollers. In LC1, replaced the whole paper cassette drawer 3 with no luck. Anyone else come across this problem???
  • Bix
    • Apr 2018
    • 1421
    Re: Konica Minolta Bizhub C754. Paper Cassette Tray 3 jams
    Hi have you tried to check with sensor check if everything is correct? Jam Code?
    • Alex1
      • Oct 2012
      • 285
      I chance cleaned all the sensors, there is no actual error just multiple jam locations and I need to clear them.
      OTE=Bix;898157]Hi have you tried to check with sensor check if everything is correct? Jam Code?[/QUOTE]
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        [/QUOTE]
        Are the jam codes set to display in the service mode? Even if they aren't you can check the codes in chronological order via the "Paper Jam History" in service mode.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • allan
          RTFM!!
          • 5459
          Switch 11 bit 7 to 1 to get the jam codes to display on the copy screen.
          Guess J-13XX would be in history.
          Whatever
          • Alex1
            • Oct 2012
            • 285
            I'll take a look today and see what comes up.
            Are the jam codes set to display in the service mode? Even if they aren't you can check the codes in chronological order via the "Paper Jam History" in service mode.[/QUOTE]
            • Alex1
              • Oct 2012
              • 285
              How do I do that. I assume it's in service mode??
              • allan
                RTFM!!
                • 5459
                Yes. under system 2 and software switch settings.
                Refer to the manual.
                Or just look for the display jam code option.
                Whatever
                • Alex1
                  • Oct 2012
                  • 285
                  [/QUOTE]
                  I tried uploading the image taken, however i keep getting errors to upload. but the machine displays sections jamming 1,2,3,11,13, and 12 as multiple sheet jams. its expected as its multiple pages printed however if i do multiple prints from paper cassette drawer 4 it works perfectly fine.
