Konica Minolta C353 Grinding Noise
  • icafe
    • Oct 2019
    • 2
    Hi,
    I need help with my Konica Minolta C353, when switched on, it makes some grinding noise and it says Waste toner box needs to be replace and waste toner box seems empty. I really don't have idea if the grinding noise is related to the waste box or something else. I will really appreciate any help.
    Thanks..
  • Zeldaman
    • Mar 2011
    • 946
    Re: Konica Minolta C353 Grinding Noise
    Hi there!
    I think you have a great doorstopper now. The waste-toner tubes are clogged, in worst case the gears are gone. Fixing that is a hell of a ride!
    Greetings...
    • icafe
      • Oct 2019
      • 2
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      Thanks for your answer, what do you think I can do? can it be fixed ? or is the machine could possibly not be useful anymore.. {Scrap}
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Honestly???? - SCRAP
        Greetings...
        • copyman
          Owner / Technician
          • Sep 2005
          • 4646
          Not sure how it can be assumed right away that waste tube is clogged. Before pronouncing the machine dead you have to empty waste box and vacuum out waste toner shute where it goes into waste box. Also pull the transfer belt and vac out transfer belt cleaning unit, make sure gears turn freely on the cleaning unit. If waste box is empty than maybe the waste toner would have somewhere to go!
          • sanvicente
            • Aug 2011
            • 31
