AccurioPress C6100
  • bluebear
    • Jul 2014
    • 16
    AccurioPress C6100
    Hi Gent,
    I have this error code C2237 come up on Accurio Press C6100, can someone help interpret this or advise how to resolve the issue please?
    Thank you
  • Toxic
    • 697
    Re: AccurioPress C6100
    It should be this.
    The IDC shutter home
    sensor (PS19) does not
    become active after a
    specified period of time
    elapses since the IDC
    shutter motor (M36)
    becomes active.
    Open front door,pull out process unit,remove transfer belt.
    Below drum k is IDC sensors located,check sensor shutter plate is it moving freely left and right,clean shutter home sensor.
    If not familiar with this machine better call some CE before you make more possible damage.
    • bluebear
      • Jul 2014
      • 16
      Many thanks for the feedback, I will work above procedure on Monday and feedback.
      Much appreciate your enormous help.
        • 23008
        If its anything like the C1060 you may find that the shutter does not open quite far enough. It's a very simple mechanism made of sheet metal, and it only took a little tweaking to make the shutter open more fully when actuated. =^..^=
        • bluebear
          • Jul 2014
          • 16
          I have carefully followed procedure above, it seem there is no power coming to the motor (IDC shutter motor) hence shutter is not does not open and shutter properly.Error code has also changed from C2237 to C2236 reboot.
          Planning to replace motor, anyone has the part number please?
          Many thanks to all, much appricate.
          • Toxic
            • 697
