Konica C360i missing secure print tab
  • steve schofield
    • May 2010
    • 117
    Hi all
    we have set up many devices with the secure tab on home screen , we have a Konica C360i and display screen is set to classic style but when secure print is set to nothing appears, konica have suggested f/w but device is on current f/w , only difference with other I series machine is this device has Fiery but we really cant see how this would affect.??? any answers greatly appreciated.
  • Bix
    • Apr 2018
    • 1421
    Re: Konica C360i missing secure print tab
    Is the error correct in the job list?
    Which driver are you using? Universal or specific?
    • steve schofield
      • May 2010
      • 117
      thanks for the reply , issue is with no tab on home screen of copier , not driver related as this is at PDI stage , we have removed and added userbox tab no problem but no secure tab showing...done the normal admin>system settings>custom display>main menu default settings>system userbox >secure print, everything goes in fine but no display tab on home screen. we have same model next to machine and shows fine?? f/w and movie data all updated hdd on......
      • Bix
        • Apr 2018
        • 1421
        with the G00-73 mobile icons have been added
        • steve schofield
          • May 2010
          • 117
          G00-73 is current on machine...many thanks
          • Bix
            • Apr 2018
            • 1421
            When you press the wheel on the left of the main screen, then at the top right you can add tabs. Have you seen if it is present? I think I saw it
            But any way you can use it:
            [Classic Style]
            • Synthohol
              Certified Konica Expert
              • 5849
              Can't you add the tab just like you did when the fiery tab was added?
              Just add it.
              • steve schofield
                • May 2010
                • 117
                • tec
                  • Jun 2012
                  • 7
                  Check the following:
                  Admin mode, security, user box usage restriction, secure print user box....set to 'Do Not Limit'
                  • steve schofield
                    • May 2010
                    • 117
                    Hi All
                    thanks for replies , Tec that worked thank you .
                    • Michko
                      • Sep 2010
                      • 32
                      Hi All
                      did you have to do anything more?
                      I still cant get it to work.
                      Print sercure go to mfp, type in.... error nothing there.
