BH C454e C-D385 error
  • copier tech
    • 8221
    [Error Code] BH C454e C-D385 error
    Hi all,
    After a routine service & updating the firmware the machine throws D385 so after choosing 'recover data' it just sits doing nothing for hours.
    This error is not listed in the service manual so am bit stuck on how to proceed?
  • tsbservice
    Field tech
    • 8064
    • copier tech
      • 8221
      Re: BH C454e C-D385 error
      Tried to above from service manual.
      Replaced SSD & HDD same issue.
      • ScouseTech
        • Nov 2019
        • 3
        Did you resolve this? I think I may have the same issue.
        I suspected SSD board but you've already done that.
        Did you loose any counter data?
        • copier tech
          • 8221
          Hi,
          Yes we replaced a new ssd & mfp counters were reset but machine working ok.
          • ScouseTech
            • Nov 2019
            • 3
            Hi,
            Cheers, that's exactly what I've ordered.
            • copier tech
              • 8221
              This was a tough fault as D385 error was not in the manual!
              • ScouseTech
                • Nov 2019
                • 3
                Yes I spent a good few hours on it today, mine had lost all its counter data including service counters an jam counters.
