Konica Minolta Bizhub C554e Stapling Problem
  • Guest
    Hello,
    I want to print on a Konica Minolta Bizhub C554e from the app Preview on my MacBook using the option to staple my printed sheets. The problem is that I can't activate the option to staple my printed sheets. The error message is that it results in a conflict as soon as I activate "Staple" (no matter which option I choose for stapling). Does anybody have an idea why this doesn't work?
    My guess would be that stapling is not compatible with the option binding. The problem is I can't deactivate binding on Mac (I can only choose the binding position). Am I missing something?
    If I print from Adobe Acrobat the menu looks a bit different but the problem is the same as in Preview.
    If I print from a Windows PC it's no problem to active the staple option.
    Versions: macOS 10.14.6, printer driver 5.4.0 (latest version available)
    Thank you!
    Best regards
    Mark
    • 22997
    Re: Konica Minolta Bizhub C554e Stapling Problem
    I not sure exactly how you do this on a MAC, but it sounds as though you need to configure the driver to show that the finisher is available. =^..^=
    • Guest
      You're right, the finisher has to be activated, now it works!
      macOS: System Preferences > Printer & Scanners > choose printer > options
      Thank you!
      • tsbservice
        Field tech
        • 7972
        This is common user mistake that even experienced techs fall in that trap, I'm not saying that I'm experienced with KM, but with Toshibas I was
