Standby Bizhub C258
  • Bix
    • Apr 2018
    • 1421
    Standby Bizhub C258
    Hi, I recently updated a bizhub C258 to the recent G00-X4 for new CSRC configurations on Friday.
    Today the multi-function printer did not recover from standby. I had the main switch turned off and on again and I deactivated the weekly timer and reduced the aggressiveness of energy saving.
    Initially it had the default energy saving settings. Now with the new changes I don't think it will happen again
    Any experience with the G00-X4?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4789
    Re: Standby Bizhub C258
    I know with the "4" series we turned off the sleep mode in every one because of trouble waking up. Service mode, sleep mode, "permit", than enter admin mode, energy save settings, sleep mode off.
    • Bix
      • Apr 2018
      • 1421
      Yes I do it
      Strange that this happen also in 8 series
      Before the update fw, this not happen
      • emujo2
        • Mar 2017
        • 1579
        Cannot verify this on the 8 series, but older e series, no matter what the power save settings were, would shut off after 72 hours. E
        • tech51
          • 846
          Try setting the following.
          Low power 60 minutes
          Sleep off
          Enter power save - normal
          Power consumption - disabled
          Weekly timer - off
          On the print driver, make sure wake on lan is ticked.
          Been using these settings for a few years now without any issues.
          • Bix
            • Apr 2018
            • 1421
            Yes, at the installation I usually impose this but sometimes I let it go, theoretically doing this the multi-function printer loses the Energy Star certification
            • ivovb
              • 695
              Did You enter MAC?
              I have such a problem even in newest c250i. Here is my working combination for c250i
              Administrator Settings - Maintenance - Timer Settings - Power Settings - Power Key-Power Save; Power Save-Sleep - Next - Power Consuption-Disabled
              Weekly Timer - Weekly timer on/off - Sleep
              BR
              I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
              • Bix
                • Apr 2018
                • 1421
                Be careful on the C250i, the problem may be "more serious".
                Can't print or don't even scan work?
                If you can't just print, the problem may be in the driver. But if the printer can't even scan, the problem I think is like the one in this discussion: C250i going offline and noisy
                It is still not clear if it is a firmware or hardware bug, we are still investigating. Currently with the firmware version F00-75 it is not happening but it may be too early, being an almost random problem.
